I need to remove the jsession ID from my client browser. The jsession id is not used but when a client makes the initial connection to my web site the browser inserts a jsession ID then the server switches to using cookies and puts the jsession ID in the cookie. So I need to prevent it from being generated and used in the URL for the initial connection.
Is this done through an irule when HTTP_RESPONSE {
Check if response is a redirect and the Location header has a jsessionid
if { [HTTP::header Location] contains ";jsessionid="}{
Remove ;jsessionid= up until a ? which starts the query string
HTTP::header replace [string map [list [findstr [string tolower [HTTP::header Location]] ";jsessionid=" 12 "?"] ""] [HTTP::header Location]]
