Help with LocalLB::Monitor::create_template
Hi, I’m trying to do two things with iControl using Perl:
1) Create a monitor template
2) Set the attributes of the template
In advance I’ll say that I’m not too hot at creating data structures, so I’m terribly sorry for my hackish looking code. I used the SDK reference for LocalLB::Monitor::create_template.
First, the monitor template:
When I run the script, I get this error:
SOAP-ENV:Server Cannot convert a struct to a string.
I’m going to paste the dump of the structure first, followed by the code:
$ ./create_template_test.pl $VAR1 = [
‘is_read_only’ => 0,
‘is_directly_usable’ => 1,
‘timeout’ => 16,
‘interval’ => 5,
‘dest_ipport’ => {
‘ipport’ => {
‘address’ => ‘192.168.1.5’,
‘port’ => ‘80’
‘address_type’ => { ‘ATYPE_EXPLICIT_ADDRESS_EXPLI CIT_PORT’ => ‘192.168.1.5:80’
‘parent_template’ => ‘’
Here’s the code:
!/usr/bin/perl
use SOAP::Lite;
use Data::Dumper;
my ( $sUID, $sPWD, $sHost, $sMonitor ) = ( ‘admin’, ‘somepassword’, ‘10.10.0.1’, ‘test_monitor’ );
Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials
return “$sUID” => “$sPWD”;
$monitor = SOAP::Lite
→ uri(‘urn:iControl:LocalLB/Monitor’)
→ readable(1)
→ proxy(“https://$sHost/iControl/iControlPortal.cgi”);
Attempt to add auth headers to avoid dual-round trip
eval { $Pool->transport->http_request->header
‘Authorization’ =>
'Basic ’ . MIME::Base64::encode(“$sUID:$sPWD”, ‘’)
Main logic
CREATE DATA STRUCTURE
my @monitor_struct1;
my $template_def =
template_name => ‘test_template1’,
template_type => ‘HTTP’
push @monitor_struct1, $template_def;
my @monitor_struct2;
my @monitor_struct3; for dest_ipport
my @monitor_struct4; for address_type
my @monitor_struct5; for address and port
my @monitor_struct6; test
my $address_type_attr =
ATYPE_EXPLICIT_ADDRESS_EXPLICIT_PORT => ‘192.168.1.5:80’
push @monitor_struct4, $address_type_attr;
my $address_port_attr =
address => ‘192.168.1.5’,
port => ‘80’
push @monitor_struct5, $address_port_attr;
my $dest_ipport_attr =
address_type => @monitor_struct4,
ipport => @monitor_struct5
push @monitor_struct6, $dest_ipport_attr;
my $template_attr =
parent_template => ‘’,
interval => 5,
timeout => 16,
dest_ipport => @monitor_struct6,
is_read_only => 0,
is_directly_usable => 1
push @monitor_struct2, $template_attr;
print Dumper(\@monitor_struct2); exit;
END DATA STRUCTURE
$soapResponse = $monitor->create_template(
SOAP::Data->name(templates => [@monitor_struct1]),
SOAP::Data->name(template_attributes => [@monitor_struct2])
&checkResponse($soapResponse);
print “Monitor $sMonitor created successfully\n”;
checkResponse makes sure the error isn’t a SOAP error
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, “\n”;
exit();
I haven’t even gotten to 2, setting the monitor attributes, since I can’t create one yet.
Can someone please give me a tip on what I’m doing wrong here? Thanks so much.
Justin
Instead of digging through your code, I’ll take the easy way out and toss along some code that has worked for me in the past. Let me know if it doesn’t work and I’ll try to dig into yours a bit more:
sub createMonitorTemplate()
    $MonitorTemplate = {
        template_name => "joestemplate",
        template_type => "TTYPE_ICMP"
    $IPPortDefinition = {
        address => "10.10.10.10",
        port => 80
    $MonitorIPPort = {
        address_type => "ATYPE_STAR_ADDRESS",
        ipport => $IPPortDefinition
    $CommonAttributes = {
        parent_template => 'icmp',
        interval => '60',
        timeout => '15',
        dest_ipport => $MonitorIPPort,
        is_read_only => "false",
        is_directly_usable => "true"
    print "Creating Monitor Template...\n";
    $soapResponse = $Monitor->create_template(
        SOAP::Data->name(templates => [$MonitorTemplate]),
        SOAP::Data->name(template_attributes => [$CommonAttributes])
Hope this helps out. Again, let me know if not, and I’ll see what I can do to get yours working for you…
-Joe
Joe, much thanks for the support. It worked great.
Can some one post exactly how the XMLRequest looks for this operation
