We are trying to load balance some members which vend ldaps with selfsigned certs. I don’t really want to import the CA or anything like that… but I am unable to get the members to go active. The members have reverse DNS that matches the cert name (which the F5 Config Guide says is required).
b monitor ad_ldaps_monitor list
monitor ad_ldaps_monitor {
defaults from ldap
debug "no"
mandatoryattrs "no"
password "xxxxxxxxx"
security "ssl"
username "xxxxxxx"
passwd "xxxxxxxx"
b pool addev_pool_ldaps list
pool addev_pool_ldaps {
lb method least conn
monitor all ad_ldaps_monitor
members
111.111.111.111:ldaps
222.222.222.222:ldaps
333.333.333.333:ldaps
We are running 9.4.8 so I don’t believe we are effected by the bug in 9.4.5
We had a similar problem when we upgraded to 9.4.5 a couple of years a go. I don’t know if it’s still relevant for your version but these are steps that we followed that F5 support forwarded on.
Iain
1. The new openldap installation uses /usr/etc/openldap/ldap.conf as its config file by default. Also the new library requires certificate checking by default. In this ldap.conf file you need to add the line:
TLS_REQCERT never
NOTE: The cr I file will change the config file the openldap library uses back to /etc/ldap.conf to avoid changes in 2 following.
2. Unfortunately subdomain does not allow access to this newly formed ldap.conf file, you need to add this for it to work.
2a. Add the following line to /etc/subdomain.d/usr.bin.bigd:
