What version are you running? Is there any error in the \var\log\ltm? The iRule looks valid on version 9.x it will cause the VIP to bind to TMM0 is on a newer platform. If you are running 10 or above you need o rewrite the iRule using the class command.
if {not ([class match [IP::client_addr] equals SS_CMS_Nets]) and ([class match [string tolower [HTTP::uri]] contains SS_CMS_URLs]) } {
HTTP::redirect "/"
Guys, thanks very much. I have only got around to testing this today. The rule seems to ignore all IP addresses listed in SS_CMS_Nets and redirects every client to “/”
