Help with iRule
I am a beginner with writing iRules and it would be great to get some tips on where to start.
My requirements are i need to do a health check against a web server by doing HTTP get on a file (blah.pac) and checking for a string within the file. If the string is there then the server is available if not then bring the server down.
Any help would be greatly appreciated.
Regades,
David
Hi David,
You can use a health monitor to do this. You can check the LTM config guide for your version on AskF5.com to get details on how to do this.
Aaron
