I’m currently in a bit of a pickle for developing an iRule solution to avoid HTTPS_Rewrite for certain URL’s.
I currently have an LTM VS configured which has a profile that rewrites all redirects to HTTPS.
ltm profile http HTTPS_Rewrite {
app-service none
defaults-from http
enforcement {
unknown-method allow
redirect-rewrite all
For most of the redirects, I want the redirect response to be HTTPS which is why this is applied. There are two instances however, where I want the URL redirect to be HTTP.
For instance, for redirects to “www.one.com” & “www.two.com”, we don’t want the profile to rewrite it to HTTPS.
create ltm rule http-response-specific {
when HTTP_RESPONSE {
if { HTTP::header value Location contains onetwo-list }
I think replacing the Locaton Variable will be too much of a headache, is it possible to identify the location variable and then bypass the profile entirely for connections with these urls?
I’m not certain I’ve understood the question correctly.
When I need to redirect all sites to HTTPS except a select few domains, I do like Vijay: create an irule
set vhost [string tolower [HTTP::host]]
switch $vhost {
"http-domain1.local" -
"http-domain2.local" {
#now it uses the default settings of the vs, including any default pool you might have selected
default {
#Send a redirect to https - 307 to tell the client that it needs to use the same method as when it send the request to this port
HTTP::respond 307 Location "https://[getfield [HTTP::host] ":" 1][HTTP::uri]"
If you have a lot of sites that need the exception you might be better served with a data group. It will make the irule shorter, however, every time you troubleshoot you’ll have to look an additional place.
I actually managed to write an iRule while keeping the profile attached. I was looking for some order of operations as to whether the profile or iRule was triggered first and it wound up being the profile.
On the ‘HTTP_Response’, I just modified the 'Location Header to replace ‘https’ with ‘http’.
