Help With HTTP_RESPONSE
Hello Gurus
Could someone help me with a quick rule to replace a header in the response back to the client, please?
My problem is like follows: we have a poxi app (not proxy) and the damn thing is sending a redirection back to the client to localhost instead of maintaining the hostname that requested the initial page and the protocol
I was talking with the developers and they they don’t have an estimate for a fix (I’m gonna kill them soon) and reading through the posts I believe my interim solution will be arounf HTTP_RESPONSE actions in the iRules.
How can I use iRules in the response to the client to replace the beging of the redirection (http://127.0.0.1) with the protocol and host that was made for that request (https://acme.com) and maintain the reamining of the redirectied URI (/some/redirected/path/to/the/client.jsp)
Thanks in advance,
Adrian
Is the host that made the request (https://acme.com) a fixed value or is it something that changes and must be read from the request?
That should be read from the request as it can change in protocol, i.e HTTPS vs. HTTP
The SSL is terminated on the LTM when the request comes over HTTPS.
Thanks,
Adrian
set shost [getfield [HTTP::host] “:” 1]
set suri [HTTP::uri]
when HTTP_RESPONSE {
if { [HTTP::status] starts_with “3” } {
HTTP::redirect https://$shost$suri
Nice and slick, thanks.
In the HTTP_RESPONSE, do I have visibility to the headers send back by the app? I am interesting the “Location:” header which comes from the app server in this form:
I need to replace the content of that header with
where $shost is picked up in the HTTP_REQUEST and the should be the same that the client originally requested (could be either HTTP of HTTPS, so it is not always HTTPS or HTTP), which I believe that can be pickeup on the HTTP_REQUEST as well.
Thanks,
Adrian
Adrian,
Is the inbound ports the standard ports for HTTP and HTTPS?
They are standard ports for HTTP and HTTPS.
I believe it could be something like this, but I failed to substract from the location header the part that I’m insterested:
set smethod [HTTP::HTTP::method]
set rlocation [HTTP::header “Location”]
set ruri
HTTP::header replace Location $smethod://$shost$ruri
How do I extract the URI form the Location header in the response from the client?
set sport [getfield [HTTP::host] “:” 2]
if { $sport equals “443” } {
HTTP::redirect http://$shost$suri
The should due the trick.
hmmm… i don’t really think so… maybe I did not say it right in the first place. sorry…
I cannot tell what’s the requested URI and what’s the “desired” redirected URI from the original request.
Here how the dynamics are:
- the client does a request (HTTP or HTTPS) to lets say /index.jsp (i.e http://acme.com/index.jsp or https://acme.com/index.jsp)
- the app behind, makes a decision internaly where to send the client for its next request and sets the Location header as part of the redirect process (is not the LTM who does the redirection)
- the problem is that the app sends http://127.0.0.1/nexthop.jsp (could be http://127.0.0.1/any/other/path/hop.jsp as well) for the Location where the client needs to go next
- I need to intercept this Location header in the response from the app (it is just a portion of the total requests that are wrongly redirected by the app, not all - don’t ask me, I haven’t designed the app, I just need to provide the workaround until devs are getting their story straight) and change “http://127.0.0.1” with the original method and the original host name that the user requested in the first place, but to maintain the actual URI that is set by the app (as said, that is unknown to the LTM as it is built inside the app logic where the client is redirected after initial request). The final Location header send back to the client should be http://acme.com/nexthop.jsp or https://acme.com/nexthop.jsp or http://acme.com/any/other/path/hop.jsp or… I don’t know what’s it gonna be in the HTTP_REQUEST (the app logic is not at the LTM level)
Thanks,
Adrian
Ok I understand now. Sorry for the confusion. You are correct in the stripping of the location header and pulling out the URI. Unfortunately this is the way you will have to do it.
That Location header will be in this form (I got a header sniff on the replies)
If I put
HTTP::redirect http://$shost$clocation
where clocation is gotten from
set clocation [HTTP::header “Location”]
would that not result in a final (?):
http://$shosthttp://127.0.0.1/nexthop.jsp
I’d say something like this would do the trick:
set rurl [split $rlocation /]
set ruri /[join [lrange $rurl 3 end] /]
Would you agree? Not sure if my TCL is right to extract the actual string from the location header…
Thanks,
Adrian
How about like this…
set rurl [string range $rlocation 0 15]
I believe that this should set $rurl to $rlocation minus the first 16 characters.
wow, i’m not that good on tcl (not good at all i should say)
I might be wrong here, but from the tcl manual:
string range string first last
Returns a range of consecutive characters from string, starting with the character whose index is first and ending with the character whose index is last. An index of 0 refers to the first character of the string. An index of end (or any abbreviation of it) refers to the last character of the string. If first is less than zero then it is treated as if it were zero, and if last is greater than or equal to the length of the string then it is treated as if it were end. If first is greater than last then an empty string is returned.
So, that would return me in the rulr the actual bit I want to get rid off: http://127.0.0.1
If i read the manual right, the way to do it would be:
set rurl [string range $rlocation 16 end]
… I believe.
I complentely agree that needs to be tested. I’ll try to crop something up tomorow (gmt time here) before I go live.
Thank again for your time and thoughts,
Adrian
A couple of notes/suggestions:
HTTP::method (Click here) won’t return the protocol used for the request (HTTP or HTTPS). It will return the method used in the request (GET, HEAD, POST, etc).
If you want to determine whether to use HTTP or HTTPS in the Location header value, you can either assume it based on whether the rule is added to an HTTP or HTTPS virtual server, or for wildcard port virtual servers you can check the requested port (using TCP::local_port in the client side context).
The HTTP::host command will return what the client entered after the protocol (http:// or https://) and before the start of the URI (/path/to/file.txt) in the address bar of the browser. For example, if a client requested https://test.example.com:80/index.jsp?pageno=1, HTTP::host would return test.example.com:80. Most clients don’t make requests which include the port number though. Unless the requested URL contained the port, splitting the HTTP::host value on a colon and taking the second field will not return anything.
If you want to replace a string within a string in TCL, you can use the string map command (http://www.hume.com/html84/mann/string.html). The format is: string map “find1 replace1 find2 replace2” original_string. If you’re using literal strings for the find/replace, you can use {}'s instead of the “”'s.
You can test basic commands in the RULE_INIT event. This event is triggered when the rule is created or saved. You don’t have to assign the rule to a virtual server even. You can check the /var/log/ltm log file for the log output. It can be an easy way to check string commands and others that are allowed in the RULE_INIT event. Here’s an example:
when RULE_INIT {
    save a sample string to the $::location_test variable
   set ::location_test "http://127.0.0.1/path/to/file.txt"
    save a sample HTTP host header value
   set ::host_test "www.example.com"
    log the value
   log local0. "Sample Location header value: $::location_test"
    replace the string "127.0.0.1" with the test host header value
   log local0. "Updated string 1: [string map "127.0.0.1 $::host_test" $::location_test]"
    replace the strings "http://" with "https://" and "127.0.0.1" with the test host header value
   log local0. "Updated string 2: [string map "http:// https:// 127.0.0.1 $::host_test" $::location_test]"
This logs the following:
Rule : Sample Location header value: http://127.0.0.1/path/to/file.txt
Rule : Updated string 1: http://www.example.com/path/to/file.txt
Rule : Updated string 2: https://www.example.com/path/to/file.txt
Based on that, you can build an example to perform the actual replacement of the Location header in 3xx redirect responses coming from the pool members. This one checks the port the client made a request to. If it was 443, then any instance of http:// in the Location header will be replaced with https://. If the port wasn’t 443, then only the 127.0.0.1 string is replaced.
    Save host (without the port if it's specified)
   set shost [getfield [HTTP::host] ":" 1]
   log local0. "Parsed Host header value: $shost"
    check if response is a redirect (HTTP status of 3xx)
   if { [HTTP::status] starts_with "3" } {
       Save original Location value
      set location_original [HTTP::header value Location]
      log local0. "Original Location header value: $location_original"
       Check if the port the request was made on was 443
      if {[clientside {TCP::local_port}] == 443}{
          Request was made to an SSL port, so replace 127.0.0.1 with the Host header value from the request
            and replace http:// with https:// in the Location header value
         set location_updated [string map "http:// https:// 127.0.0.1 $shost" $location_original]
         log local0. "Updated Location header value for HTTP request: $location_updated"
          Perform the actual header replacement
         HTTP::header replace Location $location_updated
          Request was made to an HTTP port, so just replace 127.0.0.1 with the Host header value from the request
         set location_updated [string map "127.0.0.1 $shost" $location_original]
         log local0. "Updated Location header value for HTTPS request: $location_updated"
This logs the following for an HTTP request followed by an HTTPS request:
: Parsed Host header value: 192.168.101.42
 : Original Location header value: http://127.0.0.1/test/file.txt
 : Updated Location header value for HTTP request: https://192.168.101.42/test/file.txt
 : Updated Location header value for HTTPS request: http://192.168.101.42/test/file.txt
The above example uses extra variables so you can log the intermediate steps. It could be streamlined to remove the extra variables.
Hope this helps…
Aaron
Thanks Aaron.
I have loccaly tested your solution and works like a charm.
The production changes will be scheduled in the next couple of days and I don’t suspect any issues.
Devcentral rocks as always!
Thanks to all,
Adrian
That’s good to hear. Here is a version without the logging and intermediate variables:
    Check if response is a redirect (HTTP status of 3xx)
         HTTP::header replace Location [string map "http:// https:// 127.0.0.1 $shost" [HTTP::header value Location]]
         HTTP::header replace Location [string map "127.0.0.1 $shost" [HTTP::header value Location]]
Aaron
Hi fellows,
Nothing to do with this topic
I have posted an issue on this forum and in need to resolve it the earliest possible., and so far, a couple views and no hints.
Could someone point me to a source of info i.e other forums etc.
cheers
t0
Hey, this is VERY helpful.
But not quite what the doctor order for my case of improper returnURLitus.
In my case, I have an SSO product that is mangling the original URL on redirect to login from an SSL frontend. Both servers are fronted by the BigIP, both running SSL on the BigIP.
So client requests https://serv1:443/page
The SSO webagent looks at the authentication headers and redirects to login page on https://serv2:443/login?encoded\_original\_urlhttp://serv1/page
The encoded URL now says “http” instead of “https” because the agent does not understand he is “https” on the front end.
So after successful login the client is redirected back to his original URL sans the little secure “S” in the scheme of the URL, i.e. http://serv1:443/page
But I do have unsecure port 80 pages on serv1, so this example would rewrite everything unsecure to secure and that’s not quite what I need.
Can I check the Location’s port for 443 and then replace “http://” with “https://” instead of checking clientside port for 443?
Or is there any easier way to make my virtual server on the BigIP listen to non-ssl and ssl on 443 and redirect the non-ssl requests to ssl?
This works… on the server that sends the last redirect to the original URL. Not intiutive, though, is it?
if { [HTTP::header value Location] contains “:443” } {
Request was made to an SSL port, replace http:// with https:// in the Location header value
set location_updated [string map "http:// https:// " $location_original]
log local4. “Updated Location header value for HTTP request: $location_updated”
