Hi! I have ~15 partitions and want to filter out two partitions. I’ve read this and thought this would be a valid query:
https://fqdn:443/mgmt/tm/ltm/profile/client-ssl/?$filter=partition+eq+PART-1+or+partition+eq+PART-2
But I’m getting the following error:
Text: u'{"code":400,"message":"Query parameter $filter has invalid value partition eq PART-1 or partition eq PART-2.","errorStack":[]}'
The partition names is PART-1 and PART-2 and I want all client SSL profiles in those partitions. If I filter for only one partition it works fine:
https://fqdn/mgmt/tm/ltm/profile/client-ssl/?$filter=partition+eq+PART-1
