I need your help on deploying F5 BIG-IP with SWG (Secure Web Gateway) and APM (Access Policy Manager) (i.e. Web Proxy) functionality using forward proxy feature.
Can you please let me know how do I go about doing this?
I have tried to use the guide to deploy F5 BIG-IP as a explicit Forward Web Proxy using the Secure Web Gateway (SWG) but it does not seem to work on my test lab.
Is it possible to skip section of AAA (Create an Active Directory AAA) section and rather do authentication based on the source subnet?
Thanks for the update Dave, really appreciate your reply on this.
I have checked the deployment guide and it says that you can allow connection based on the Source IP subnets on APM rather than through AAA (AD servers), but I don’t know how to achieve this.
Can anyone please help with SWG and APM deployment on F5 based on IP subnets rather than using AAA (Active Directory servers) for authentication?
Using show and tell, I have already tried but the solution isn’t working the, I will compensate you for your time/efforts. (can you pls contact me on Pushkin.Sawhney@gmail.com).
