I’ve been trying to get this iRule to work and have followed many other (much older examples) in this forum and some blog posts:
Basically, we have 4 VIP’s:
1. Port 443 with ssl client profile (clear text from LTM to server)
2. Port 80
3. Port 1443
4. Port 8444
All pointing to the same pool, which is a wildcard pool
VIPs 1 and 2 map to 8443 in the iRule
What happens is when the client connects to 443, the session is created, but the next request to say port 8444 or 1443 go to a different node in the pool and a new persistence record is created for this new connection.
I’ve tried many different iterations and so far I can’t crack it. I hope someone here can help
when CLIENT_ACCEPTED {
set def_pool [LB::server pool]
set retries 0
Calculate destination port based on destination port and IP address
switch [TCP::local_port] {
80 { set port 8443 }
443 { set port 8443 }
default { set port [TCP::local_port] }
check for existing persistence record
if it exists, directly select node by address:port
set persist "[IP::client_addr] any virtual"
log local0. "\$persist = $persist"
set server [session lookup uie [list $persist]]
if {($server != "") && ($port != "")}{
log local0. "Found record [IP::client_addr]:[TCP::client_port] -> [IP::local_addr]:[TCP::local_port] -> $def_pool $server:$port"
pool $def_pool member $server:$port
node $server $port
when SERVER_CONNECTED {
Debug logging. Remove/comment out this event when done testing
log local0. "Connected [IP::client_addr]:[TCP::client_port] -> [IP::server_addr]:[TCP::server_port]"
when LB_SELECTED {
add/refresh session table entry (5 min timeout)
if {$server >= "1"}{
log local0. "[IP::client_addr]:[TCP::client_port] -> [IP::local_addr]:[TCP::local_port] persistent to = $server"
set server [IP::client_addr]
if {$server != ""}{
session add uie [list $persist] $server 300
log local0. "Add Record uie $persist $server:any 300"
LB::reselect
log local0. "no server selected"
when LB_FAILED {
set server [session lookup uie {[IP::client_addr] any virtual}]
if connection fails, log & reselect a new server in same pool, up to the number of available servers
if { $retries < 1 } {
persist none
LB::mode rr
LB::detach
LB::reselect
incr retries
log local0. "Selected server $server:$port did not respond. Re-selecting node"
log local0. " -> [IP::client_addr]:[TCP::client_port] -> [IP::local_addr]:[TCP::local_port]"
