I need an iRule to translate all URLs on Headers and Payloads of Request and Response events.
Let’s say that I have one site “public.com” for the clients, and inside on the DMZ network, there are servers with host “inside.corp”. Then I need to replace all the HTTP::host with something like:
HTTP::header replace Host "inside.corp"
But my problems come when I need to search in the HTTP::payload to replace all the href=“inside.corp/asdf.htm”… or the tag img src=“inside.corp/image.jpg” etc URLs…
If I use another iRule to make HTTPS Redirect, and using the same HTTP_REQUEST events, which iRule will be issued first? And in case of HTTP_RESPONSE? I assume that iRules with same events executes in the same order of the Virtual Server Resource list…Could this iRule be like this?
set inside "inside.corp"
set outside "public.com"
if { [HTTP::host] eq $outside } {
HTTP::header replace Host $inside
if { [HTTP::version] eq "1.1" } {
if { [HTTP::header is_keepalive] } {
HTTP::header replace "Connection" "Keep-Alive"
HTTP::version "1.0"
when HTTP_RESPONSE {
if { [HTTP::header "Content-Type"] starts_with "text/" } {
if { [HTTP::header exists "Content-Length"] } {
set content_length [HTTP::header "Content-Length"]
if { $content_length > 0 } {
HTTP::collect $content_length
when HTTP_RESPONSE_DATA {
regsub $inside [HTTP::payload] $outside fixeddata
log "Replacing payload with fixed data."
HTTP::payload replace 0 $clen $fixeddata
HTTP::release
Can I use HTTP 1.1 instead of 1.0 or is better that way?
Thanks a lot!
