Help with a redirect with a uri modification.
I am having an issue where I need to redirect a particular site on SharePoint to a different server farm.
I would like to see and anything that comes after the apr redirected to and include the anything after the apr from above
so if I go to he would get redirected to
but if sally came along and went to she would get redirected to
I have this already and it kinda works
    if { [HTTP::uri] contains "/apr" } {
        HTTP::redirect "https://sharepoint2/sites/apr"
The problem is everything gets redirected to /sites/apr and doesn’t include /chris or /sally. I know that is what my irule says to do but how would I include whatever is in the rest of the string after /apr and change the /techservices/govern to sites?
Thanks in advance for any help.
Hi Chris,
you may try the snippet below. It uses the
[string range]
syntax, to cut the first 20 characters from the requested
[HTTP::uri]
to build the redirect location…
    if { [string tolower [HTTP::uri]] starts_with "/techservices/govern/apr" } then {
        HTTP::redirect "https://sharepoint2/sites[string range [HTTP::uri] 20 end]"
Cheers, Kai
