I am trying to do a redirect which will look like below:
hostname.domain.com/abc/varying_remainder_uri redirect to NEWhostname.domain.com/def/varying_remainder_uri
I did the below which I know is not correct:
if { [HTTP::uri] contains “abc”} {
HTTP::redirect “]”
It does the redirect, but keeps the “abc” in the uri so the resulting redirect looks like this:
https://NEWhostname.domain.com/def/…der_of_URI
Assuming the /abc/ and /def/ portions of the URI are static, you could use some string mapping:
if { [string tolower [HTTP::uri]] starts_with "/abc"} {
set newuri [string map {"/abc/" "/def/"} [string tolower [HTTP::uri]]]
HTTP::redirect "https://NEWhostname.domain.com$newuri"
Thanks Kevin, Yes the abc and def parts of the uri are static. I tried the rule you listed, but it does not seem to be working.
Let’s try some logging then to verify if the iRule is producing what you want:
log local0. "original URL = [HTTP::host][HTTP::uri]"
if { [HTTP::uri] starts_with "/abc/"} {
log local0. "new URL = https://NEWhostname.domain.com$newuri"
Please report back what the logs return.
Scratch that Kevin, I went back and tried it again before putting the logging on and it worked fine. Maybe something was “stuck” in my browser session that cleared. Thanks so much for the help!!
