help troublshooting or reconfiguring an irule
Currently the CAS server is doing the redirect, terminating the SSL, and providing the OWA logon page… The F5 was set up for ‘Performance L4’ and load balancing.
I was attempting to integrate our enterprise vault solution today. The plan was to use the existing exchange virtual server and iRules to direct traffic to the enterprise vault pool.
I changed the VS type to standard and created the following irules… I see the 1st 80 redirect rule working, but I don’t see any traffic hitting the pool and I think I need a little assistance… Attached is a generic diagram of the EV/Exchange set up.
HTTP Virtual:
When HTTP_REQUEST {
if { [HTTP::uri] contains “enterprisevault” }{
HTTP::redirect “https://webmail.company.com/enterprisevault/”
} elseif { [HTTP::uri] equals “/” }{
HTTP::redirect “https://webmail.company.com/owa”
HTTPS Virtual:
if { [string tolower [http_uri]] equals “/enterprisevault” } {
pool enterprise-vault
log local0. “match for ev”
pool exchange2007-owa
if { [string tolower [http_uri]] equals “/enterprisevault” } {is it “/enterprisevault” or “/enterprisevault/”?
by the way, http_uri is HTTP::uri, isn’t it?
Sorry, another piece of information to further complicate things… I do not have the SSL client profile configured with a valid cert. The CAS servers have the cert on them and will continue to redirect 80 traffic and terminate SSL. Will I have to install the cert/key pair on F5 as well? And if so, I assume I can use the default server profile ‘server-sslinsecure-compatible’? And that will not interfere with my enterprise vault pool listening on port 80.
Yes the LTM will reset the traffic as you have a HTTP profile on the VIP and the traffic is non-RFC HTTP. WIth out the Client-ssl profile the LTM will not be able to read any of the traffic.
Will I have to install the cert/key pair on F5 as well?yes, you should import certificate and key from server to bigip and set it in clientssl profile. you are able to use default clientssl profile but user will get certificate warning page when accessing https virtual server.
And if so, I assume I can use the default server profile ‘server-sslinsecure-compatible’?yes, you can use default serverssl-insecure-compatible on server-side i.e. custom clientssl profile on client-side and default serverssl-insecure-compatible on server-side.
And that will not interfere with my enterprise vault pool listening on port 80.not really sure if i understand correctly. anyway, i understand there are 2 pools; exchange pool is listening on port 80 and 443 and enterprisevault is on port 80. you have 2 virtual servers but same virtual address; one is on port 80 and the other one is on port 443, and you want to direct traffic to pool based on url.
so, i think configuration may look like this.
[root@ve10:Active] config  b virtual bar80 list
virtual bar80 {
   destination 172.28.19.79:80
   ip protocol 6
   rules myrule80
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b rule myrule80 list
rule myrule80 {
   if { [string tolower [HTTP::uri]] contains "enterprisevault" }{
      HTTP::redirect "https://[HTTP::host]/enterprisevault"
   } elseif { [HTTP::uri] equals "/" }{
      HTTP::redirect "https://[HTTP::host]/owa"
[root@ve10:Active] config  b virtual bar443 list
virtual bar443 {
   snat automap
   destination 172.28.19.79:443
   ip protocol 6
   rules myrule443
   profiles {
      clientssl {
         clientside
      http {}
      serverssl {
         serverside
      tcp {}
[root@ve10:Active] config  b rule myrule443 list
rule myrule443 {
   if { [string tolower [HTTP::uri]] equals "/enterprisevault" } {
      SSL::disable serverside
      pool foo80
      pool foo443
[root@ve10:Active] config  b pool foo80 list
pool foo80 {
   members 200.200.200.101:80 {}
[root@ve10:Active] config  b pool foo443 list
pool foo443 {
   members 200.200.200.101:443 {}
Has anyone gotten this to work? We are running Enterprise Vault with OWA, and I can’t get enterprise vault accessible from the outside.
I have been messing around with the iRules and now instead of a page cannot be displayed error, I am getting a 404 error.
Any update? Because we have the same issue and either F5 nor veritas could give us the right solution.
We have Exchange DAG 2013 multirole and Enterprise Vault. From external ( OWA) we cannot use Enterprise vault.
