Help to write the Monitor script
Hi, my server response is like this, when I accss the URL on HTTPS
{“myStatus”:“OK”,“datapowerStatus”:{“status”:“OK”,“message”:“{\“result\”: {\“domain\”: \“My_StubServices\”}}”,“millisecondsTaken”:47},“myDatabaseStatus”:{“status”:“OK”,“message”:“DBName: my-training-db”,“millisecondsTaken”:11},“loggingDatabaseStatus”:{“status”:“OK”,“message”:“DBName: my-training-log-db”,“millisecondsTaken”:69}}
My intention is to write a monitor (HTTPS), so it search the string “OK” in the response, and then counts it, and if the count is equal or more than 4, then set the monitor as pass.
thanks in advance.
have you started with something we could help with or expect a full solution here?
Try using Regex in Monitor: SOL5917
A full solution will be proffered, as I am new to the coding world. many thanks
I would appreciate if a full solution or a steps involved can be described a bit in detail please.
Will you clarify if the content of the response containing the “OK” string is returned in a single or multiple lines?
thanks for looking into this, actually on the webpage it displays the response in 2 lines as text, nothing special..and another thing would there be much difference because the url is HTTPS and not HTTP. Regards
this shows pretty well how to go about it
This one should do it:
!/bin/sh
 these arguments supplied automatically for all external pingers:
 $1 = IP (::ffff:nnn.nnn.nnn.nnn notation or hostname)
 $2 = port (decimal, host byte order)
 $3 and higher = additional arguments
 $MONITOR_NAME = name of the monitor
 In this sample script, $3 is the regular expression
 Name of the pidfile
pidfile="/var/run/$MONITOR_NAME.$1..$2.pid"
 Send signal to the process group to kill our former self and any children
 as external monitors are run with SIGHUP blocked
if [ -f $pidfile ]
then
   kill -9 -`cat $pidfile` > /dev/null 2>&1
fi
echo "$$" > $pidfile
 Remove the IPv6/IPv4 compatibility prefix
node_ip=`echo $1 | sed 's/::ffff://'`
 Using the nc utility to get data from the server.
 Search the data received for the expected expression.
count=$(echo -en "GET / HTTP/1.0\n\n\n\n" | nc $node_ip $2 2>/dev/null | egrep -v '200 OK' 2>/dev/null | tr -d -c 'OK' 2>/dev/null | awk '{ print length; }' 2>/dev/null)
if [ ! -z "$count" ]
then
    count=$(($count+0))
    if [ $count -gt 8 ]
    then
     Remove the pidfile before the script echoes anything to stdout and is killed by bigd
    rm -f $pidfile
    echo "up"
    fi
fi
 Remove the pidfile before the script ends
rm -f $pidfile
 END.
You need to modify it to put in the URI specific for your application.
Edit: The count should be 8 or greater.
OK you can use a standard monitor, which is preferred over an external monitor, and use the following as the receive string:
:\"OK\".*:\"OK\".*:\"OK\".*:\"OK\"
