I have an iApp application which has 4 VIPS which have the same pool (pool 1). (they share a single pool).
I need to create a pool (Pool 2) with ephemeral node which will auto populate the pool members.
Now I need to monitor this pool 2, and this monitor should be on the pool 1.
So the monitor on pool 1 should monitor pool 2 (pool 2 can be dummy pool with no traffic going there)
Is it possible?
Thanks , Aditya
