Hello
I am newbie to F5’s and LTM’s and trying to use Universal persistence to have clients persist to a server if the serve has field of ID= and then two characters e.g. ID=25. If the field is not present then persistence is not required.
Trying to understand difference between the two following iRules, which appear to do what I need, but not sure which is best approach.
iRule 1 – Just using the HTTP Request
set sessid [findstr [HTTP::uri] "ID=" 3 2]
if { $sessid != "" } {
persist uie $sessid
iRule 2 – Checking HTTP Response and Request.
when HTTP_RESPONSE {
if {$sessid != ""} {
persist add uie $sessid
set sessid [URI::query [HTTP::uri] "ID="]
persist uie $sessid
Could somebody be kind enough to explain the difference and merits of each?
Think of it like a database table. Each of the persistence options (except cookie) stores some information about the client and chosen server in a record in that table (in memory on the BIG-IP), so that when the client returns with a new request the server can identify the client, look up the table entry, and load balance accordingly. Source and destination address persistence use the client’s source or server’s destination address, respectively, while universal persistence is basically an open table that you can store anything in. The first iRule above looks for an ID value in the request URI and load balances that based on a match in the uie table (universal inspection engine). But wait. When did a value ever get stored in that table? In the second iRule, the HTTP_RESPONSE is looking for an ID in the URI, but there’s not going to be a URI in a response, so that persist add is not going to happen and so you’re back to looking for a persistence record in the request that never exists. You can verify all of this by looking at persistence records with tmsh:
tmsh show ltm persistence persist-records
Ultimately for universal persistence to be effective, you need the server to send something that you can grab in a response, and that the client will transmit back in every request. This is why cookie persistence is usually the best choice, because it’s basically automatic for any browser-based application.
Hi Kevin
Thanks for the answer. Bit clearer now. I believe the session ID is sent in Location field, but still awaiting confirmation. Assuming it is would the below be a good approach to capture the session in the response and check requests.
if {[HTTP::header exists Location]} {
get next 2 characters after ID= and assign value to parameter sessid
set sessid [findstr [HTTP::header Location] "ID=" 3 2]
If value for sessid is not empty add a persistance entry
persist add uie $sessid 600
log local0. "[IP::client_addr]:[TCP::client_port], Session ID: $sessid, created persist record: [persist lookup uie $sessid]"
log local0. "[IP::client_addr]:[TCP::client_port], No Session ID"
if { [HTTP::uri] contains "ID=" } {
If value is not empty then persist on the session ID
persist uie $sessid }
if value is empty then no persistence
else {
persist none
