help: Need more details from the logs
I’ve created a pool with two http server nodes and assigned a HTTP monitor. We occasionally see one of the nodes health monitor give a false fail and traffic gets sent to the other server (we suspect this is due to server load) so to test different types of monitor I created a new test pool with the same servers nodes as above and assigned my test monitors.
My problem is that I don’t know how to see what specific monitor (live or test) failed as all I see in the logs is “Pool member 10.12.22.18:80 monitor status down.”
How can I get a more granular log of what pool member failed and why?
Thanks for any help.
You can enable a database key to instruct bigd by running ‘b db bigd.lognodestatuschange enable’ from the command line to print the monitor name which failed when a pool member is marke down. See this post (Click here) for details.
Aaron
Thanks Aaron this is exactly what I need.
