Hello every one… I am setting exchange 2010 on BIG-IP 10.2.1 Build 511.0 Hotfix HF3, following the Deployment Guide http://www.f5.com/pdf/deployment-guides/f5-exchange-2010-dg.pdf. I am use the Template for Exchange 2010, this template generate an iRule named Exch_2010_single_Persist_irule (view original iRule in the pag 56 of deployment guide).
iRule to select pool and persistence method when all Exchange
Client Access services are accessed through the same BIG-IP
virtual server.
switch -glob [HTTP::path] {
“/Microsoft-Server-ActiveSync*” {
Direct all ActiveSync clients to a common pool; use
HTTP cookie persistence
persist cookie
pool Exch_2010_single_as_pool
log local0. “host [HTTP::host] url [HTTP::uri] Persistencia”
HTTP::class disable
“/rpc/rpcproxy.dll” {
Grab all requests for Outlook Anywhere; the following
checks assign correct persistence methods.
switch -glob [HTTP::header “User-Agent”] {
“MSRPC” {
This User-Agent section matches most versions of
Outlook and Windows using Outlook Anywhere.
The OutlookSession cookie is new to Outlook 2010.
if { [HTTP::cookie exists “OutlookSession”] } {
persist uie [HTTP::header “OutlookSession”] 3600
else {
persist uie [HTTP::header “Authorization”] 3600
“*Microsoft Office*” {
This section matches some versions of
Outlook 2007 on Windows XP
default {
This section catches all other requests for
Outlook Anywhere, and sets a persistence method
that does not require the client to support
HTTP cookies
persist source_addr
Finally, this assigns the Outlook Anywhere pool and turns
off full HTTP parsing and compression. If the preceding
clients should be sent to separate pools, the pool statement
should be removed here, and a separate pool statement
placed in each of the preceding logic branches.
Other modules (APM, ASM, etc.) should be disabled here
as well, if active for other traffic though this virtual
server.
pool Exch_2010_single_oa_pool
HTTP::disable
COMPRESS::disable
CACHE::class disable
log local0. “host [HTTP::host] url [HTTP::uri] Anyware”
“/xml/autodiscover.aspx” {
Requests for Autodiscovery information. The selected pool
might be unique, or might be the same as e.g. your pool
for OWA or ActiveSync. In this example, we use the same
pool that receives ActiveSync traffic.
persist cookie
log local0. “host [HTTP::host] url [HTTP::uri] AuteSync”
HTTP::class disable
default {
This final section takes all traffic that has not
otherwise been accounted for and sends it to the
pool for Outlook Web App
persist cookie
pool Exch_2010_single_owa_pool
log local0. “host [HTTP::host] url [HTTP::uri] Owa”
If using the Web Accelerator module, uncomment the
following line and change the name to that of
your WA class.
HTTP::class select Exch_2010_class
log local0. “host [HTTP::host] url [HTTP::uri] WebAcelerator”
Checking logs, found the next error
Jun 10 10:26:51 local/tmm err tmm[5201]: 01220001:3: TCL error: Exch_2010_single_Persist_IRule_irule - Prerequisite operation not in progress (line 1) invoked from within “HTTP::host” (“/rpc/rpcproxy.dll” arm line 51) invoked from within “switch -glob [HTTP::path] { “/Microsoft-Server-ActiveSync*” { Direct all ActiveSync clients to a common pool; use …”
Any idea…?
