help implementing i-rules
I just need to compose an i-rule to impose secure loging. At present it works fine in a dx box from junper with a so called ptc rule. The ptc rule is rewriting a part of the contents. This has now to be done by a big-ip version 9.3x.
the first I rule applies to http to redirect to https this works fine.
rule for http
if { [HTTP::uri] contains “/Logon/ProcessLogon.asp?iscontained=Yes”} {
HTTP::redirect “https:://”[HTTP::host][HTTP::uri]"
} elseif { [HTTP::uri] contains “interop” } {
pool HFM-Prod-interop
} else
{pool HFM-Prod }
rule for https
if { [HTTP::uri] contains “../home/home.asp?iscontained=Yes” }{
HTTP::redirect “http://[HTTP::host][HTTP::uri]”
} else
{pool HFM-Prod }
so far so good. However the https rule should do more and replace content data
to this rule the following should be added. I give first the ptc rule as applied in the redline
PTC: content contains “” then replace content term “”
in the above lines the “\” are escapes for the redline to ignore the next character.
I suppose this should be used in the BIG-IP as well for " and ( ) do have meaning in parsing.
in simple language the following should happen
if the content contains:
then replace the content with:
In the above I took away the escapes needed for the redline
Who can help me do solve this problem
I would apply a stream profile against your https virtual:
profile stream replace_content_1 {
   defaults from stream
   source ""
   target ""
I tried to implement the given rule but to no avail, I keep getting errors.
Next I tried to implement the next rule but it generates the error in the I rule editor “line 9: [unknown event (STREAM_MATCHED)] [when STREAM_MATCHED {”
the rule I tried is given below.
if { [HTTP::uri] contains “../home/home.asp?iscontained=Yes”} {
HTTP::redirect “https:://[HTTP::host][HTTP::uri]”
pool hfm-prod-interop
} else
{pool hfm-prod }
if{ [STREAM::match] contains “”} {
STREAM::replace “”
who knows the answer
