i have oracle 11i and its working fine. I want to do load balances between two Oracle server by LTM. i go by the F5 guide to do every thing. The missing point with me is Oracle part. i don’t now what is the change i need to do on oracle so every thing will be done on it. i dont have much idea on oracle so if one can give me the step by step will be grate. Help!!!
Have you checked the F5 deployment guides for Oracle? - Click here
This is where I’d start. There’s tons of great information in the deployment guides. Hopefully that’ll get you going in the right direction.
Colin
