I’ve recently converted from 4.5 to 9.05 and converted my iRules, using OTCU then tweaking so they are correct (at least what I though was correct).
When connecting to a web site, the rule basically connects you to a different pool depending on the port that the client web browser uses.
My old rule (below) worked:
if (server_port == 80) {
use pool wwwDEFAULT
else if (server_port == 8001) {
use pool node-10.128.32.1
else if (server_port == 8099) {
use pool node-10.128.32.2
else if (server_port == 8003) {
use pool node-10.128.32.3
else if (server_port == 8004) {
use pool node-10.128.32.4
else if (server_port == 8005) {
use pool node-10.128.32.5
else if (server_port == 8006) {
use pool node-10.128.32.6
else if (server_port == 8007) {
use pool node-10.128.32.7
else if (server_port == 8008) {
use pool node-10.128.32.8
else if (not (server_port == 80 or not (server_port == 8001 or
not (server_port == 8099 or not (server_port == 8003 or
not (server_port == 8004 or not (server_port == 8005 or
not (server_port == 8006 or not (server_port == 8007 or
not (server_port == 8008)))))))))) {
redirect to "http://www.vetsite.net"
else {
discard
The converted one doesn’t seem to
if { [TCP::client_port] == "80" } {
persist source_addr 1800
HTTP::fallback http://support.blackwellpublishing.com
pool wwwDEFAULT
elseif { [TCP::client_port] == "8001" } {
elseif { [TCP::client_port] == "8099" } {
elseif { [TCP::client_port] == "8003" } {
elseif { [TCP::client_port] == "8004" } {
elseif { [TCP::client_port] == "8005" } {
elseif { [TCP::client_port] == "8006" } {
elseif { [TCP::client_port] == "8007" } {
elseif { [TCP::client_port] == "8008" } {
elseif { not [TCP::client_port] == "80" or not [TCP::client_port] == "8001" or
not [TCP::client_port] == "8099" or not [TCP::client_port] == "8003" or
not [TCP::client_port] == "8004" or not [TCP::client_port] == "8005" or
not [TCP::client_port] == "8006" or not [TCP::client_port] == "8007" or
not [TCP::client_port] == "8008" } {
HTTP::redirect "http://www.vetsite.net"
else {
discard
When the web browser trys to connect to the web site that it is trying to view (on HTTP port 80) it says ‘website found waiting for reply’ and seems to spend an eternity waiting before timing out.
If I dump the rule and make the virtual server use pool wwwDEFAULT directly all is fine.
I can’t see any problems that would cause this, am I going mad?
I haven’t tested any of this, but I would mention a couple things. You are using tcp::client_port where I think that is going to be the source port. You would want to use tcp::local_port which is the destination port.
Also, you’re doing when HTTP_Request when you should probably be using when CLIENT_ACCEPTED. This happens higher in the stack, so it should be more efficient.
Something like this:
when CLIENT_ACCEPTED {
if { [TCP::local_port] equals 531 } {
pool win2003
} elseif { [TCP::local_port] equals 25 } {
pool win2003
pool win2003
Another thing worth noting is that the “not” operator is of higher precendence that it used to be in 4.x (basically 4.x did a better job of figuring out what you wanted to do, but because we are using Tcl now, we don’t have that same flexibility with the precedence of the operators). So, make sure you add parenthesis around the expression that is the target of the not operator, as in:
elseif { not ( [TCP::client_port] == "80" ) or not ( [TCP::client_port] == "8001" ) or
not ( [TCP::client_port] == "8099" ) or not ( [TCP::client_port] == "8003" ) or
not ( [TCP::client_port] == "8004" ) or not ( [TCP::client_port] == "8005" ) or
not ( [TCP::client_port] == "8006" ) or not ( [TCP::client_port] == "8007" ) or
not ( [TCP::client_port] == "8008" ) } {
I would also suggest using a class to help minimize the number of these tests as in:
elseif { not [matchclass [TCP::local_port] equals $::server_ports] } {
You can also use citizen_elah’s example above which relies even more on the class (you may want to add a test of $match to make sure a match was found before do the “pool node-$match” though).
