set myIpH [format %08x $myIpE] set myIpD1 [expr 0x[substr $myIpH 6 2]] set myIpD2 [expr 0x[substr $myIpH 4 2]] set myIpD3 [expr 0x[substr $myIpH 2 2]] set myIpD4 [expr 0x[substr $myIpH 0 2]] set myIpD “$myIpD1.$myIpD2.$myIpD3.$myIpD4” log local0. “Server Ip address = $myIpD” node $myIpD 4244 unset myIpE unset myIpH unset myIpD1 unset myIpD2 unset myIpD3 unset myIpD4 unset myIpD unset unused
Want to know what does this mean and do. Sorry i am very new to irules.
This script part is within a context, so I will not alter or suggest any content here.
This way, I think this code snippet is related to a cookie persistence. See:
So, I think this propose to do the following:
Given a cookie value: 1677787402.36895.0000
Catch IP address block
myIpE: 1677787402
Convert value to Hex
Result: 6401010a
Catch Ip address octets
Result: 0x0a => 10
Result: 0x01 => 1
Result: 0x01 -> 1
Result: 0x64 => 100
Concat to give the server IP address
set myIpD "$myIpD1.$myIpD2.$myIpD3.$myIpD4"
Result: 10.1.1.100
Write a log on the /var/log/ltm
log local0. "Server Ip address = $myIpD"
Result: Server Ip address = 10.1.1.100
Select node and port 10.1.1.100:4244
node $myIpD 4244
Dispose variables
unset myIpE
unset myIpH
unset myIpD1
unset myIpD2
unset myIpD3
unset myIpD4
unset myIpD
unset unused
I hope it helps.
Regards.
