Heat Maps irule by Colin.
Thanks to Colin Walker for the great heatmap’s irule.
I have tried to implement this irule but run into some problems and not sure where to look..Below is what I see in the log files..
If I have the IP randomization part of the code left in then the site (app, not the heatmaps site) loads every other time. Also I had commented out the
HTTP::respond 200 Content “Added”
Else I see Added on the real site instead of the homepage.
Please help.
Thanks,
-jay
Aug 26 17:09:42 local/tmm err tmm[5151]: 01220001:3: TCL error: heatmap_irule - Illegal value (line 1) invoked from within “table incr -subtable countries -mustexist $cloc” (“default” arm line 12) invoked from within "switch -glob [string tolower [HTTP::uri]] { “/asia” - “/africa” - “/europe” - “/middle_east” - “/south_americ…”
Aug 26 17:09:42 local/tmm1 err tmm1[5152]: 01220001:3: TCL error: heatmap_irule - Illegal value (line 1) invoked from within “table incr -subtable countries -mustexist $cloc” (“default” arm line 12) invoked from within "switch -glob [string tolower [HTTP::uri]] { “/asia” - “/africa” - “/europe” - “/middle_east” - “/south_americ…”
Aug 26 17:09:42 local/tmm1 info tmm1[5152]: 01220001:6: Per-invocation log rate exceeded; throttling.
Aug 26 17:09:42 local/tmm info tmm[5151]: 01220001:6: Per-invocation log rate exceeded; throttling.
Aug 26 17:09:54 local/tmm1 info tmm1[5152]: 01220001:6: Resuming log processing at this invocation; held 8 messages.
I modified it a bit, assuming you didn’t need the randomization logic.
when RULE_INIT {
  set static::resp1 "Here is your site's usage by Country:
Zoom to region:  |  |  |  |  |  | "
    "/asia" -
    "/africa" -
    "/europe" -
    "/middle_east" -
    "/south_america" -
    "/usa" -
    "/world" -
    "/heatmap*" {
      set chld ""
      set chd ""
      set zoom [string map {"/" "" "heatmap" "world"} [HTTP::uri]]
  Configure the table query to be based on the countries subtable or the states subtable
      if {$zoom eq "usa"} {
        set region "states"
        set region "countries"
  Get a list of all states or countries and the associated count of requests from that area
      foreach rg [table keys -subtable $region] {
        append chld $rg
        append chd "[table lookup -subtable $region $rg],"
      set chd [string trimright $chd ","]
  Send back the pre-formatted response, set in RULE_INIT, combined with the map zoom, list of areas, and request count
      HTTP::respond 200 content "${static::resp1}${zoom}&chd=t:${chd}&chld=${chld}${static::resp2}"
    "/resetmap" {
      foreach country [table keys -subtable countries] {
        table delete -subtable countries $country
      foreach state [table keys -subtable states] {
        table delete -subtable states $state
      HTTP::respond 200 Content "
Table Cleared.
    default {
  Look up country & state locations
      set cloc [whereis [IP::client_addr] country]
      set sloc [whereis [IP::client_addr] abbrev]
  Set Country
      if {[table incr -subtable countries -mustexist $cloc] eq ""} {
          table set -subtable countries $cloc 1 indefinite indefinite
  Set State
      if {[table incr -subtable states -mustexist $sloc] eq ""} {
          table set -subtable states $sloc 1 indefinite indefinite
Give that a few shots and if you get TCL errors about variables not existing, we can add some catch logic…
Hi Jay,
What version of LTM are you running?
-George
v10.2 on 3600’s .But this is for our staging environment, once this works, I will move it to prod, where I have 9.4 and 10.1 (10.2 in the future).
Hi Jay,
I figured out what is going on here and was able to reproduce the problem in my environment as well. It looks like because you are accessing the virtual from a non-routeable IP, it is setting the country and state to null. When it hits the line that attempts to increment the value of the null key, it pukes. You could add a catch or set all null values to XX or some other non-existent country code. Hope this helps,
George
Another note: this iRule won’t work on version 9.4 as tables weren’t available until version 10.1.
-George
Posted By watkins on 10/06/2010 01:34 PM
Hi Jay,
George
Hi George,
Can you tell me how I am accessing the virtual from a non-routeable IP? I thought it was generating random IP’s as part of the code for testing?
Thanks,
Jay
Sorry, I was using the code that Chris had posted and it was not using the random IP stub. Could you re-post your code using the code encapsulation so I can paste it into my LTM?
-George
Hi Jay,
I can’t copy and paste your code without it being formatted using the code markup. I also can’t tell if it has been modified from Colin’s original post. What I can tell you is that the $cloc is being set to a null value and that is what is causing the “Illegal value” error.
-George
Sorry I hope the below works.
when RULE_INIT {
   Configure static portions of the HTML response for the heatmap pages
   set static::resp1 "
Table Cleared.
     default {
   If the IP doesn't resolve to anything, pick a random IP (useful for testing on private networks)
       if {($cloc eq "") and ($sloc eq "")} {
         set ip [expr { int(rand()*255) }].[expr { int(rand()*255) }].[expr { int(rand()*255) }].[expr { int(rand()*255) }]
         set cloc [whereis $ip country]
         set sloc [whereis $ip abbrev]
         if {($cloc eq "") or ($sloc eq "")} {
             set cloc "US"
           set sloc "WA"
   Strip slashes from URI to allow easy queries
       set friendlyURL [string map {/ ""} [HTTP::uri]]
   Create a new table named country:location or state:location
set cloc "country:$cloc"
       if {[table incr -subtable $cloc -mustexist $friendlyURL] eq ""} {
         table set -subtable country:$cloc $friendlyURL 1 indefinite indefinite
   Update the mytables pointer table with the new country or state table name
       if {[table incr -subtable mytables -mustexist country:$cloc] eq ""} {
         table set -subtable mytables country:$cloc 1 indefinite indefinite
   Same as above for states, not countries.
       if {$cloc eq "US"} {
         if {[table incr -subtable state:$sloc -mustexist $friendlyURL] eq ""} {
             table set -subtable state:$sloc $friendlyURL 1 indefinite indefinite
         if {[table incr -subtable mytables -mustexist state:$sloc] eq ""} {
             table set -subtable mytables state:$sloc 1 indefinite indefinite
       HTTP::respond 200 Content "Added - Country: $cloc State: $sloc"
 } Here is your site's usage:\
 Connections per Region:
   set static::resp2  "
Zoom to region:\
   set static::resp4 ""
 when HTTP_REQUEST timing on {
     "/asia*" -
     "/africa*" -
     "/europe*" -
     "/middle_east*" -
     "/south_america*" -
     "/usa*" -
     "/world*" -
     "/heatmap*" {
       set chld ""
       set chd ""
       set zoom ""
       set zoomURL ""
       set regions ""
       set urlTotal 0
       set regionTotal 0
   Split apart the zoom region from the filter URL in the request
       set zoom [getfield [string map {"/" "" "heatmap" "world"} [HTTP::uri]] "?" 1]
       set zoomURL [getfield [string map {"/" "" "heatmap" "world"} [HTTP::uri]] "?" 2]
   Get a list of all states or countries, applying the URL filter where necessary
   and retrieve the associated count of requests from that area to that URL
     First step through the mytables table, which is a pointer table referencing all subtables with counter values in them
       foreach mysub [table keys -subtable mytables] {
     Next determine whether to search state or country tables
           if {$mysub starts_with "state:"} {
     For each state sub table step through each key, which will be a URL, and count the request to that URL.
     This is also where URL filtering is applied if applicable
             foreach myurl [table keys -subtable $mysub] {
               if {$zoomURL ne ""} {
                 if {$myurl eq $zoomURL} {
                   append chld "[getfield $mysub ":" 2]"
                   append chd "[table lookup -subtable $mysub $myurl],"
                   set urlTotal [table lookup -subtable $mysub $myurl]
               set regionTotal {expr $regionTotal + $urlTotal}
               set urlTotal 0
             append regions "[getfield $mysub ":" 2] : $regionTotal"
             set regionTotal 0
           if {$mysub starts_with "country:"} {
                 set urlTotal 0
                 set urlTotal 0
             set regionTotal 0
     First loop through the trackingurls class to get a list of all URLs to be tracked and format HTML around them for links
       set filters ""
       foreach mytrackingurl class names trackingurls {
         append filters " | "
       set filters [string trimright $filters " | "]
     Combine the above generated HTML with the static HTML in RULE INIT and respond to the client
      HTTP::respond 200 content "${static::resp1}${regions}${static::resp2}${zoom}&chd=t:${chd}&chld=${chld}${static::resp3} \
      Filter by URL:  | $filters\
      $static::resp4"
     "/resetmap" {
       foreach pointertable [table keys -subtable mytables] {
         foreach entry [table keys -subtable $pointertable] {
           table delete -subtable $pointertable $entry
       foreach pointerentry [table keys -subtable mytables] {
         table delete -subtable mytables $pointerentry
any thoughts?
Ive tried this rule out as well and had to edit it to get it to work correctly. It seems the author didnt actually test the final rule. In testing the recently edited rule works fantastic and amazed my CEO; in production however, it is a different story. Within 1 min of being deployed onto our production site the Google Chart API started denying traffic. The bigIP LTM CPU ramped up to 100% and another min after that and the whole bigip LTM device crashed completely. Upon restart of the device we had to wait almost an hour for the TMM to finish cleanup before traffic started serving again. Here is the modified rule that caused the trouble.
when RULE_INIT {
      set static::resp1 ""
if {  [HTTP::uri] != "/"}  {
       "/asia*" -
       "/africa*" -
       "/europe*" -
       "/middle_east*" -
       "/south_america*" -
       "/usa*" -
       "/world*" -
       "/heatmap*" {
         set chld ""
         set chd ""
         set zoom ""
         set zoomURL ""
         set regions ""
         set urlTotal 0
         set regionTotal 0
                 set regionTotal [expr $regionTotal + $urlTotal]
                 set urlTotal 0
               set regionTotal 0
                   set urlTotal 0
                     set urlTotal 0
               set regionTotal 0
         set filters ""
         foreach mytrackingurl [class names trackingurls] {
        HTTP::respond 200 content "${static::resp1}${regions}${static::resp2}${zoom}&chd=t:${chd}&chld=${chld}${static::resp3}Filter by URL:  | $filters $static::resp4"
      "/resetmap" {
Table Cleared."
      default {
    If the IP doesn't resolve to anything, pick a random IP (useful for testing on private networks)Uncomment for test.
              set cloc "US"
            set sloc "WA"
        if {[table incr -subtable country:$cloc -mustexist $friendlyURL] eq ""} {
Uncomment if you want to see what state you are coming from.
 site usage Heatmap:Connections per Region:
      set static::resp2  "
Click to zoom to region: |  |  |  |  |  | "
      set static::resp4 "
Jason are you planning on doing more testing and using in prod?
Thanks,
Jay
Can you post the recent entries from /var/log/ltm before the failure occurred?
Aaron
HI Aaron,
Actually except for the URL section the irule works now, I started agin.
here it is:
when RULE_INIT {
   set static::resp1 "
Table Cleared.
     default {
             set cloc "US"
           set sloc "WA"
 Here are the logs:
 Feb 11 17:20:35 local/tmm1 err tmm1[7379]: 01220001:3: TCL error: heatmaps_part3_irule  - Illegal value (line 1)     invoked from within "table incr -subtable country:$cloc -mustexist $friendlyURL"     ("default" arm line 38)     invoked from within "switch -glob [string tolower [HTTP::uri]] {         "/asia*" -        "/africa*" -        "/europe*" -        "/middle_east*" -        "/south_america..."
 Feb 11 17:20:35 local/tmm err tmm[7378]: 01220001:3: TCL error: heatmaps_part3_irule  - Illegal value (line 1)     invoked from within "table incr -subtable country:$cloc -mustexist $friendlyURL"     ("default" arm line 38)     invoked from within "switch -glob [string tolower [HTTP::uri]] {         "/asia*" -        "/africa*" -        "/europe*" -        "/middle_east*" -        "/south_america..."
 Thanks,
 JayHere is your site's usage:\
   set static::resp2  "
Zoom to region:\
     "/asia*" -
     "/africa*" -
     "/europe*" -
     "/middle_east*" -
     "/south_america*" -
     "/usa*" -
     "/world*" -
     "/m_a_p_s_t_a_t_s*" {
       set chld ""
       set chd ""
       set zoom ""
       set zoomURL ""
       set regions ""
       set urlTotal 0
       set regionTotal 0
       set zoom [getfield [string map {"/" "" "m_a_p_s_t_a_t_s" "world"} [HTTP::uri]] "?" 1]
       set zoomURL [getfield [string map {"/" "" "m_a_p_s_t_a_t_s" "world"} [HTTP::uri]] "?" 2]
               set urlTotal 0
             set regionTotal 0
                 set urlTotal 0
                 set urlTotal 0
             set regionTotal 0
       set filters ""
      $static::resp4"
     "/resetmap" {
I haven’t read through the iRule fully enough to understand all of the logic. But I think the immediate cause of the runtime TCL error is that $friendlyURL is null. It looks like this would happen if the URI was just forward slashes (one or more), as those are getting removed when saving the $friendlyURL variable here:
set friendlyURL [string map {/ “”} [HTTP::uri]]
Aaron
If you try to use “table incr” on a table entry which has a string for a value (and not a number), then that will give you an “Illegal value” error as you’re getting there. For instance:
table set "key" "value"
table incr "key"
will give you that error, because “value” can’t be converted to a number, so it can’t be incremented. That could be what you’re seeing.
Posted By hoolio on 02/11/2011 02:51 PM
Aaron
Hi Aaron,
I added a check if its root url only then I strip the /'s else I leave them alone.
Strip slashes from URI to allow easy queries if its no root level
if { not ([HTTP::uri] equals “/” ) } {
set friendlyURL [HTTP::uri]
This seems to be working. No errors in the logs I will request the developers to do load testing on this app.
The next question I have is regarding url classifications… I have created a data group called trackingurls in this data group I have a few URI’s that I want to categorize stats by…
on the stats page I do not see any stats based on the url’s all 0’s any thoughts?
Thanks,
Jay
Thanks for the share. it was insightful I love my heatmap suite.
