Hi Folks,
I have a monitor as follows:
monitor Application_HTTPS {
defaults from https
interval 3
recv “F5 Health Check”
send “GET /f5check HTTP/1.0\r\n”
The recv value (the Page Title) is generated by ColdFusion using an SQL Query to extract the text “F5 Health Check” from a table and so my health check reliably tests the Application end to end including it’s ability to communicate with the SQL Server.
The issue is that for every connection which is made new cookies are issued by the application. These cookies are stored in a ColdFusion table on the SQL Server. After running for several hours the tables becomes incredibly large which substantially slows down the application response time.
I am looking for a way to persist the cookie supplied in the first response to subsequent healthchecks so that the F5 will present back the cookie it has been supplied with. In the event that the cookie changes the F5 would begin persisting that cookie.
Is their anyway which this can be done?
Thanks.
Rowan
