Health Monitoring assistance
I’m not familiar with setting up health monitoring via HTTP and would like to request assistance how can I create one using parameters provided on a tech doc that seems to lack information. Basically, the URL checks if the service is running on the LB nodes. When the LB sees that a service is not running on either of the node, it should remove it from the pool. I’m not sure if the health check should be added individually to each member or from the VIP, so need the advise. Thanks in advance and appreciate the help!
HTTP Verb: GET
HTTP-200: node available
HTTP-503: node failed
URL: http:///PRCMD/HealthCheck
Poll Frequency: every 10 seconds
Add the monitor to the pool and then it will poll each pool member. 404 Page not found | BIG-IP Documentation will help you contruct you monitor. Your receive string should look for
HTTP/1.1 200 OK
