Health monitor
Hello Dears
I am trying to implement health monitor for server but the vendor inform me that the connection is being full tcp handshake (syn, syn-ack, ack), but they need for  syn, syn-ack
so in health montior how to do that ?
also is it double to change the type and parent montior on GUI is unable to edit it.
Best Regards
Hi MustphaBassim,
You can configure the pool to use the “TCP Half Open” monitor.
You can simply apply the default TCP Half Open monitor to the pool or if you need to do make changes, create a custom one using the default one as a parent and make changes to it.
Hello Dear
thnx for your replay
it seems unable to not edit anything on pool level or monitor level
Hi MustphaBassim,
Check if the account you are using has required permission (role) to make changes to the F5.
I tried to use admin account but it is the seem issue take in mind i remove the health montior from pool that was mapped to it
