Hello All,
I’m creating a Health Monitor to monitor a value returned from the node. on LTM, I can set the Receive String to be
[0-99]
Which will keep node up if value is between 0 and 99 inclusive. But on GTM, it doesn’t work with this syntax, so I have to write it as
[0-9][0-9]
Is there any other way to check if the value is below a certain number, in this case 99 (This number will vary depending on the node I’m monitoring)?
