Health Monitor Question
If we specify multiple URLs with “at least” condition, is it possible to prioritize the URL for health monitor?
i.e., if /health and /info both are provided with “at least” condition is it possible to configure /info to be of priority and if /info responds with 200, then do not bother pinging /health?
Thanks Ahmad
No. You can not prioritize. Conditions are either all or at least one.
Like User: Only1masterblaster said, its all or atleast. Maybe you can try explaining your scenario.
You got 2 monitors,
  1. /health - Are you looking for any particular content or just 200 OK response.
  2. /info - Are you just checking 200 response here.
Guess if you properly put the receive string, you wont need 2 monitors unless there’s any particular reason.
You can apply 2 monitors or one but you can not set any priority on this. You can create your own external monitors and do your prioritization as you want
both health check URLs returning 200 OK. I just need to know if there is a way to prioritize health monitors may be using an iRule?
