HEALTH MONitor HELP
I need help with writing a health monitor based on the below curl command. the below response is only displayed when -L is in the command.
curl -L http://x.x.x.x:8101/oss2/customer
<!doctype html>
<html ng-app=“oss.auth” ng-strict-di>
<head>
<meta charset=“utf-8”>
<meta http-equiv=“X-UA-Compatible” content=“IE=edge”>
<meta name=“viewport” content=“width=device-width, initial-scale=1”>
<title idle-disabled=“true”>MyHPF Unavailable</title>
<base href=“/oss2/customer/”>
<meta name=“_csrf” content=“f1fc9077-ed0b-4974-9871-4d77194f9a49”/>
<meta name=“_csrf_header” content=“X-CSRF-TOKEN”/>
<!-- Bootstrap -->
<script src="..XXXXXXXX
<script src="..XXXXXXXXXX
</head>
<body ng-cloak ng-controller=“MainController” autoscroll=“true”>
<hc-backdrop></hc-backdrop>
</body>
the client wants the pool to show up based on “hp” or “myhpf” in the above response.
will really appreciate your help with this.
Regards,
-L in curl means it follow a redirect, so you can try with -v to see what the final destination is.
that one you can then use in a regular HTTP health monitor.
