Health Monitor Help
Hi
I’m trying to create a health monitor on a LTM on v10.1
The URL via a browser is:
http://10.10.10.41:8015/probe\_dicom\_c\_echo/configure.html?alias=WFM1
The Health monitor in bigip.conf
monitor Mon_XXXX_WFM_HTTP_1 {
defaults from http
dest 10.10.10.41:8015
recv “HTTP/1.1 200 OK”
send “GET /probe_dicom_c_echo/configure.html?alias=WFM1”
I have attached this to the node 10.10.10.41, but I’m getting a fail, when I know the sites working. So I’m thinking its my GET string or recv.
Any help would be great,
thanks
g
Hi Gareth,
You can remove the destination IP and port from the monitor. If you’re applying it to that pool member, bigd will automatically use the pool member’s IP and port to make the request.
I’d guess the reason the monitor is failing is that you’re sending an HTTP 0.9 request (no version specified). Can you try:
GET /probe_dicom_c_echo/configure.html?alias=WFM1 HTTP/1.1\r\nHost: \r\nConnection: Close
and see if the monitor marks the pool member up?
Aaron
Hoolio
That worked a treat.
Thanks.
Gareth
