Health Check with Authentication when Initial URL Redirects
On an LTM with 11.4.1 code:
I’ve been tasked with creating an HTTP health check that requires authentication. But there’s a catch:
Initial call will be like http://1.1.1.1/config/ExtendedHealthcheck.hc
However, going to that initial page redirects to http://1.1.1.1/config/login.jsp which is where the login is presented. Oh, and that page presents a JSESSSIONID cookie as well. After successful login to the page you get to /config/ExtendedHealthCheck.hc where the content is returned.
I’ve searched for something similar online but can’t quite figure it out. Any ideas?
Thanks!
-Samson
Hi Samson!
I’d recommend looking at an external monitor for this. You can do a shell script with curl which could accomplish this:
Good luck!
/Patrik
Awesome - thanks for the prompt feedback! I’ll give it a whirl.
-Samson
