Hi DC,
VIP configured on port 443 and backend servers are on port 8443. Monitor send string as GET /testConnection HTTP/1.1\r\nHost: Close\r\n\r\n and applied to the pool and using SNAT automap. Traffic should come from https://abc.expert.com/testConnection
But the traffic is not coming through the https://abc.expert.com instead of https://abc.expert.com/testConnection and they are seeing Active and standby self IPs.
Any Suggestions please ?
Hello Shri@, I didn’t understand it well. The issue is regarding a wrong monitor/hostname arriving in the backend or your are expecting selfip instead float ip? Sorry but is not clear to me.
Regards.
Client saying Traffic has to come through https://abc.expert.com/testConnection but is coming from only https://abc.expert.com missing the /testConnection
So calls are dropping some time.
I am sorry for the bad explanantion.
OK no problem. Could you share that monitor setup? I still don’t know if I need to suggest a redirection/enforce “/testConnection” on client requests, or the “client” mentioned, is the server owner saying you need to monitor the correct path.
Regards.
Default https: Monitor send string as GET /testConnection HTTP/1.1\r\nHost: Close\r\n\r\n Recieve String : 200
OK, I don’t know if your example has a typo, but the monitor should be:
GET /testConnection HTTP/1.1\r\nHost: abc.expert.com\r\nConnection: close\r\n\r\n
Correct?
