I think you should find a TCL error in /var/log/ltm from trying to execute the value of [https://domain.comHTTP::uri] with the square braces that is wrapped in.
Can you clarify what you actually want to do in the Referer header update. Do you just want to replace http:// with https:// and preserve the rest of the header value? Your current rule is replacing the original Referer value with https:// and the current URI. The current URI wouldn’t typically be the same as the Referer URI.
Maybe try this:
log local0. "[IP::client_addr]:[TCP::client_port]: New [HTTP::method] request to [HTTP::host][HTTP::uri]\
with Referer [HTTP::header Referer]"
if {[HTTP::header exists "MyHeader"]} {
log local0. "[IP::client_addr]:[TCP::client_port]: Updating Referer to\
[string map -nocase {http:// https://} [HTTP::header Referer]"
HTTP::header replace Referer "[string map -nocase {http:// https://} [HTTP::header Referer]"
when HTTP_REQUEST priority 501 {
log local0. "[IP::client_addr]:[TCP::client_port] (501): Current Referer [HTTP::header Referer]"
