Header issue with VS
Hello
I have a VS https with ssl server profile on the server side and I have some troubles with the header inside the application.
Protocol : TCP
Protocol Profile client : tcp
protocol profile server : use client Profile
HTTP Profile : http
The error is as follow: 403 missing X-APPKEY header
I tried X-forwarded but I don t know what kind of http profile I can use
Bests
Hello Wanexa.
The problem doesn’t seem to be in the F5 but how you access the application (server).
Searching on internet I have found that your app could need you to pass an specific X-APPKEY header on each request (for authentication). I recommend you to check this for more info.
REF - Developer documentation | PlanningPME API
KR,
Dario.
Hi Wanexa,
your problem comes clearly from the application/client.
You have to talk with app owner. you must surely make Oauth/OIDC or some things that look like it. Your application (client / frontend) must have an appkey (X-APPKEY) and appsecret in order to communicate with backend API GW.
you can ask the owner application to provide you with the X-APPKEY that is configured (allowed)…
keep me in touch if you need more details.
regards
