Hashing Persistence
Hi Devcentral experts,
I have a bigip in front of 10 Netapp Netcaches (working as a reverse proxy). I´m using predictive node loadbalancing method.
The issue I want to address is that on some cases I can have the same object on NC1 (NetCache) than NC2, etc.
Is there any way that LTM send always a requests to the same NC using a Hashing method ?
For example:
http://www.mercadolibre.com.ar/AA --> should always go to NC1
http://www.mercadolibre.com.ar/BB --> should always go to NC2
http://www.mercadolibre.com.ar/CC --> should always go to NC3
http://www.mercadolibre.com.ar/XX --> should always go to NCXX
Thanks in advance.
Rodrigo.
iControl is our remote management API. Looks to me like you are looking for some iRules support. Try posting this over in the iRules forum and we’ll see if we can help you out.
-Joe
