We have an application that requires two connections to be made to the same member. The pool has 150+ members with several “instances” of each server on each node. I need to persist the second connection to the same member
as the original. Our connections are static - so once the second connection is persisted - I have no need for the persistance record.
We have some customers behind NATs and I want to minimize the chance that they all get stuck to the same node. I was hoping to use an iRule to play games with the persistance table. When I use the rule below I can see new persist records getting created - but all connections from teh same source go to the same member - instead of getting spread.
Here is my VIP
virtual vip1{
destination 1.1.1.1:https
mirror enable
ip protocol tcp
profile fastL4
persist hash
pool test-ssl
rule TestRule
and the rule
when RULE_INIT {
initialize global variable for counting active ssl clients
array set ::active_sslclients { }
set ::MAX_PER_CLIENT_IP 6
log local0. "ssl_vip_rule.RULE_INIT: Initialized active_sslclients global variable"
when CLIENT_ACCEPTED {
set client_ip [IP::remote_addr]
increment the count of active ssl clients for the given client ip address
if { [info exists ::active_sslclients($client_ip)] and $::active_sslclients($client_ip) >= 0 } {
incr ::active_sslclients($client_ip)
set ::active_sslclients($client_ip) 1
log local0. "ssl_vip_rule.CLIENT_ACCEPTED: client ip - $client_ip, active ssl connections - $::active_sslclients($client_ip) using MAX $::MAX_PER_CLIENT_IP"
get the batch_number so that we don't have more than MAX_PER_CLIENT_IP in one persistence hash key
for a client ip address
set batch_number [ expr ($::active_sslclients($client_ip) -1) / $::MAX_PER_CLIENT_IP ]
set hashkey "$client_ip.$batch_number"
if { [ expr ($::active_sslclients($client_ip) -1) % $::MAX_PER_CLIENT_IP] == 0}{
set batch_number0 [ expr (($::active_sslclients($client_ip) -1) / $::MAX_PER_CLIENT_IP) -1]
set hashkey0 "$client_ip.$batch_number0"
log local0. "Deleting old key $hashkey0 using new $hashkey"
persist delete hash $hashkey0
log local0. "ssl_vip_rule.CLIENT_ACCEPTED: client ip - $client_ip, persist hashkey - $hashkey"
persist hash $hashkey 30
when CLIENT_CLOSED {
decrease the count of acitve ssl connections for the given client ip address
if { [info exists ::active_sslclients($client_ip)] } {
incr ::active_sslclients($client_ip) -1
if { $::active_sslclients($client_ip) <= 0 } {
unset ::active_sslclients($client_ip)
log local0. "ssl_vip_rule.CLIENT_CLOSED: client ip - $client_ip, active count 0, unset its couunt variable"
