can anyone understand me what the difference between Hash Persistence and cookie persistence as well as what is the using of hash cookie persistence?
As well as I would like to know summary of SSL persistence , when can I use it ?
SSL Persistence: Persistence based on SSL Session ID. You can use this if you are not terminating the SSL certificate on the F5.
Hash Persistence: This is similar to UIE persistence. Basically, you can create an hash based on any “key” that is available in the incoming packet and persist based on that “key”.
Cookie Persistence: Persistence based on cookie that is stored in the client. This can be the following types:
For cookie persistence, either 1 or 2 should solve your use-case. I don’t recommend 3 or 4.
See reference link.
