Dear all;
i have a big problem.
i use F5 device for delegate DNS from DNS Server to F5 Device. ( web…)
i use sevice about one week. it hangs up. i don’t know why it hangs up. when i reboot F5 device, it work normally.
Please help me to solve it
this is log file
ltm 05-22 08:56:31 wip : info mprov:2628:: Checking for and completing any disk management transactions:
ltm 05-22 08:56:31 wip : info mprov:2628:: Invoked as: /usr/bin/mprov.pl (pid=2628) --logicaldisk --boot --quiet
ltm 05-22 08:56:32 wip : info mprov:2633:: Checking for and completing any logical disk transactions:
ltm 05-22 08:56:32 wip : info mprov:2633:: Invoked as: /usr/bin/mprov.pl (pid=2633) --diskmgmt --boot --quiet
ltm 05-22 08:56:34 wip : info mprov:2638:: /bin/mkdir -p /dev/mprov/wom
ltm 05-22 08:56:34 wip : info mprov:2638:: /bin/mkdir -p /dev/mprov/ltm
ltm 05-22 08:56:34 wip : info mprov:2638:: /bin/mkdir -p /dev/mprov/vcmp
ltm 05-22 08:56:34 wip : info mprov:2638:: /bin/mkdir -p /dev/mprov/tmm
ltm 05-22 08:56:34 wip : info mprov:2638:: Invoked as: /usr/bin/mprov.pl (pid=2638) --boot --quiet
ltm 05-22 08:56:36 wip : info mprov:2638:: /bin/mount -t hugetlbfs none /dev/mprov/tmm 2>&1 1>/dev/null
ltm 05-22 08:56:36 wip : info mprov:2638:: /usr/bin/numactl --interleave=all /sbin/sysctl -w vm.nr_hugepages=1019
ltm 05-22 08:56:36 wip : info mprov:2638:: rm -vf /dev/shm/wam.umem_shared
ltm 05-22 08:56:36 wip : info mprov:2638:: rm -vf /dev/shm/avr.umem_shared
ltm 05-22 08:56:37 wip : info mprov:2638:: Provisioning successful.
ltm 05-22 08:56:37 wip : info mprov:2638:: /usr/bin/setdb Provision.Action none
ltm 05-22 08:56:39 wip : info mprov:3147:: Provisioning (legacy update) successful.
ltm 05-22 08:56:39 wip : info mprov:3147:: Invoked as: /usr/bin/mprov.pl (pid=3147) --legacy --quiet
ltm 05-22 08:56:56 info wip chmand[4025]: >>>********** AOM **********>>>
ltm 05-22 08:56:56 info wip chmand[4025]: <<<********** BIOS **********<<<
ltm 05-22 08:56:56 info wip chmand[4025]: Latest BIOS (ver 150) already installed
ltm 05-22 08:56:56 info wip chmand[4025]: Found BIOS images /usr/firmware/c102-bios-0332-01-150.bin.
ltm 05-22 08:56:56 info wip chmand[4025]: Looking for latest BIOS image in dir /usr/firmware
ltm 05-22 08:56:56 info wip chmand[4025]: Currently installed BIOS version: 150
ltm 05-22 08:56:56 info wip chmand[4025]: >>>********** BIOS **********>>>
ltm 05-22 08:56:56 info wip chmand[4025]: BIOS: F5 Platform: C102 OBJ-0332-01 BIOS (build: 150) Date: 02/16/12
ltm 05-22 08:56:56 info wip chmand[4025]: host = Mercury
ltm 05-22 08:56:56 info wip chmand[4025]: platform = C102
ltm 05-22 08:56:56 info wip chmand[4025]: probeBits = 0x20000001
ltm 05-22 08:56:56 info wip chmand[4025]: family = 0x90000000
ltm 05-22 08:56:56 info wip chmand[4025]: systype = 0x66
ltm 05-22 08:56:56 info wip chmand[4025]: Mercury: pfm detected from /BOARD: C102
ltm 05-22 08:56:56 info wip chmand[4025]: Found platform ‘Mercury’ in /PLATFORM
ltm 05-22 08:56:56 notice wip chmand[4025]: Checking for firmware update …
ltm 05-22 08:57:01 info wip chmand[4025]: aom_flash: No CFE update required, exiting.
ltm 05-22 08:57:01 info wip chmand[4025]: Flash: CFE version: 1.5.1 (010501)
ltm 05-22 08:57:01 info wip chmand[4025]: Image: CFE version: 1.5.1 (010501)
ltm 05-22 08:57:03 info wip chmand[4025]: copying cpld image to AOM
ltm 05-22 08:57:06 info wip chmand[4025]: checking installed version:
ltm 05-22 08:57:06 info wip chmand[4025]: CPLD file expected md5sum: 2e4b79d2a48c76252bb8abc7ac8c546d
ltm 05-22 08:57:06 info wip chmand[4025]: CPLD file calculated md5sum: 2e4b79d2a48c76252bb8abc7ac8c546d
ltm 05-22 08:57:06 info wip chmand[4025]: verifying file copy:
ltm 05-22 08:57:12 info wip chmand[4025]: aom_flash: No CPLD update required, exiting.
ltm 05-22 08:57:12 info wip chmand[4025]: Cpld: v19 (base:0060)
ltm 05-22 08:57:12 info wip chmand[4025]: File: v19 (base:0060)
ltm 05-22 08:57:14 info wip chmand[4025]: MD5SUM check succeed.
ltm 05-22 08:57:14 info wip chmand[4025]: Check Image md5sum:
ltm 05-22 08:57:14 info wip chmand[4025]: Image Version: 10011103590000
ltm 05-22 08:57:16 notice wip chmand[4025]: Firmware check finished.
ltm 05-22 08:57:16 notice wip chmand[4025]: firmware update succeeded.
ltm 05-22 08:57:16 info wip chmand[4025]: <<<********** AOM **********<<<
ltm 05-22 08:57:16 info wip chmand[4025]: aom_flash: No Kernel update required, exiting.
ltm 05-22 08:57:16 info wip chmand[4025]: Flash Version: 10011103590000
ltm 05-22 08:57:20 notice wip overdog[4271]: Watchdog touch enabled.
ltm 05-22 08:57:20 info wip overdog[4271]: Overdog daemon startup.
ltm 05-22 08:57:20 info wip promptstatusd[4270]: Per-invocation log rate exceeded; throttling.
ltm 05-22 08:57:20 notice wip promptstatusd[4270]: semaphore tmm.running(1) held
ltm 05-22 08:57:20 warning wip promptstatusd[4270]: mcpd.running(1) held, wait for mcpd
ltm 05-22 08:57:20 notice wip promptstatusd[4270]: semaphore mcpd.running(1) held
ltm 05-22 08:57:20 notice wip promptstatusd[4270]: semaphore chmand.running(1) held
ltm 05-22 08:57:22 notice wip chmand[4752]: Host CPU subsystem reset caused by a Southbridge system reset
ltm 05-22 08:57:22 notice wip chmand[4752]: Host CPU subsystem reset - PCI reset asserted
ltm 05-22 08:57:22 notice wip chmand[4752]: AOM reset caused by other sources (standby power loss, JTAG or pushbutton reset)
ltm 05-22 08:57:22 notice wip chmand[4752]: CPLD indicates prior power-up or 3.3V standby power rail fault
ltm 05-22 08:57:22 notice wip chmand[4752]: CPLD indicates prior Host CPU subsystem power-off
ltm 05-22 08:57:22 notice wip chmand[4752]: CPLD indicates prior Host CPU subsystem reset
ltm 05-22 08:57:22 notice wip chmand[4752]: CPLD indicates prior AOM reset
ltm 05-22 08:57:22 info wip chmand[4752]: MCP initial connection not ready.
ltm 05-22 08:57:22 notice wip chmand[4752]: HAL sys service initialized.
ltm 05-22 08:57:22 notice wip chmand[4752]: Base service initialized.
ltm 05-22 08:57:22 notice wip chmand[4752]: Publish total 2 virtual Nitrox crypto devices.
ltm 05-22 08:57:22 notice wip chmand[4752]: Detected total 1 Nitrox crypto devices for total 2 Tmms.
ltm 05-22 08:57:22 info wip chmand[4752]: Initialized platform: C102
ltm 05-22 08:57:22 info wip chmand[4752]: host = Mercury
ltm 05-22 08:57:22 info wip chmand[4752]: platform = C102
ltm 05-22 08:57:22 info wip chmand[4752]: probeBits = 0x20000001
ltm 05-22 08:57:22 info wip chmand[4752]: family = 0x90000000
ltm 05-22 08:57:22 info wip chmand[4752]: systype = 0x66
ltm 05-22 08:57:22 info wip chmand[4752]: Mercury: pfm detected from /BOARD: C102
ltm 05-22 08:57:22 info wip chmand[4752]: Found platform ‘Mercury’ in /PLATFORM
ltm 05-22 08:57:22 notice wip chmand[4752]: Starting ChassisManager (chmand)
ltm 05-22 08:57:23 notice wip mcpd[4339]: User requested database size set to 512MB
Thanks for view
Klien.Mai
