I haven’t been able to find an answer yet for the following problem in the documentation so I’m bothering the forum with it.
I’m sandwiching a bunch of traffic inspection devices between BigIP’s. The devices are transparent on IP level, so I’m using virtual wildcard servers. The traffic flows (TCP sessions, UDP flows) can be initiated from either internal (client) or external (server) side, though usually the first flow originates from the internal side. Take as an example the “old style” (non-passive) FTP, the client initialises the control connection but the server the data connection.
How do I make sure that the same load balancing decision is made on both sides of the sandwich? I.e., if internal BigIP has decided to route ftp control connection through node N1, how do I assure that the external one routes server-initiated ftp data TCP session also through N1 and no other node?
Note that the problem is not specific to FTP, I’m merely using it as an example.
TIA,
Hannu
