Hi all, I configured HA in my lab even all the configurations are same on both the devices but it still not synchronizes the configurations on both the BIG-IPs. On both devices, it shows the redundancy state is ACTIVE and current Config/Sync state is standalone. I also reset trust all options in Device Management on both devices. But the problem is same. Please suggest me a solution.
Could you provide log file (“/var/log/ltm”) ? It’s the peer properly added in the main unit ? Device Management ›› Device Trust : Peer List
I think you missed some steps.
1.-Configuring the ConfigSync and Failover IP addresses
Device Management --> Devices --> Device Connectivity --> Config Sync
2.- Creating a Sync-Failover device group.
Device Management --> Device Groups --> Create
Take a look to the next links:
404 Page not found | BIG-IP Documentation 404 Page not found | BIG-IP Documentation
It’s working fine. Thanks a lot
