HA configuration v11.1
Hi all,
I need hel with HA configuration in V11.1
I have one bax with some VS and I need add a second box and make the HA pair.
I made Device trust, Device group, config IP Network failover IP. But devices are sill disconected.
What do I have to do?
THX
you have enabled network failover in device group (device management > device groups > name > failover), haven’t you?
Yes, net-failover is enabled.
I thik, there is some problem with device’s certificates. Do I have to run some CLI command, or something else?
Thx
is time in sync?
is there any error in /var/log/ltm?
have you ever reset trust-domain (delete cm trust-domain all)? did it help?
