I configured HA status and synch works but both devices HA status are offline. Walked through config and can’t find issue. Missing something silly.!
Hi troy
When you click on “offline” you will be redirected to a new window, from this one do you have the option to click on “Realese Offline” ?
Maybe you forced devices offline…
Check thes e articles it may help
The default provisioning is LTM only.
If you provisioned AAM, there can be two reasons
- AAM was still starting. This module can take several minutes to prepare requirements during first start.
- AAM can’t start. Some requirements are not met!
