Guys, I have a configuaration on LTM with SSL termination on LTM, but after adding client and serverssl the redirection stopped working
The virtual configuaration is :
virtual fits-prd.fmr.com-443-v-rtp { pool fits-prd.fmr.com-443-v-rtp destination 10.93.125.241:443 ip protocol 6 rules analyticsredirect-443 persist source_addr_900 profiles { fidelity-apps-http {} fidelity-oneconnect {} fidelity-serverssl { serverside } fpcms-obiee-prd.fmr.com { clientside } tcp-lan-optimized-1015 {} } }
In the above config I have a irule analyticsredirect-443 which contains:
when HTTP_REQUEST { if { [HTTP::uri] equals “/” } { HTTP::redirect “https://[HTTP::host]/analytics/” } }
But when user tried to access the url she cannot get the following page: https://fpcms-obiee-prd.fmr.com/analytics.
Same irule works for port 80. Not sure, but is it something to do with SSL profiles on port 443.
does the system function without the iRule? does the backend server even listen op port 443 (HTTPS)?
You need to define “not working”. What is the symptom? Error message? what does /var/log/ltm say? etc.
It was a problem on server end and has got resolved now. Thanks!
