I’m currently setting up a pair of GTM’s that are already sync’d as LTM’s. I verified both are running the same version of big3d and can run the “gtm_add” command from one device to the other. Sync and sync dos zone files are checked. I added a NTP server so both system clocks are the same, but for some reason, when I add a WIP after the initial setup, it doesn’t copy to the 2nd device. I’m running 11.6. Below is an output from the primary GTM to the secondary:
No errors. When I run the script, it adds the GTM and even gets the most recent data on it, but doesn’t accept any updates. I only see the connection for iquery in my initial script run via tcpdump. My netstat output doesn’t show the connections to each other via 4353.
