Hi guys,
I’m experiencing a very strange issue and I want to make sure that it is not due to my lack of understanding.
I have 2 GTM’s, certificates are ok, bigip_add was run, all iQuery stuff seems to be running fine, there are no errors in logs nor GUI.
When I add a virtual server A to a certain server A on GTM A (this server is an LTM), I enter its IP address, I enter port 3389 and I select the TCP health monitor. Now if my understanding is correct this means that either GTM itself, or a member of the prober pool assigned to this server A will execute this monitor and that the results will be communicated to the GTM A.
After the sync has occurred between both GTM’s, I check the settings of GTM B for this virtual server A on GTM server A. What I see here is that the tcp monitor is not in the selected list, whereas on GTM A it is there.
To make things worse, the virtual server is being marked ‘down’ (red status) on both GTM’s, and the message is “(Monitor /Common/tcp from gtmd : no reply from big3d: timed out)”.
I find two things odd here:
1) Why is it saying ‘no reply from big3d’ here? It’s a simple tcp monitor, and all devices capable of executing this probe have full iQuery communication capabilities with both GTM’s, there is no firewall or anything that might block this.
2) Why is the tcp monitor not syncing completely? When I look in the config (using tmsh), the tcp monitor is mentioned on both GTMs after sync has occurred, but the GUI is only showing me the monitor on the GTM on which I have created the virtual server.
Could I be running into a bug here?
All devices are running v11.2 HF1. The release notes for v11.2 HF2 don’t mention anything related to this (or at least not as far as I can tell - I did read it entirely)
Can anybody shine a light on this?
Thanks in advance,
Thomas
