Hello, everyone.
I asked you because I could not test GTM.
Capture and raise the setup screen.
Look and let me know if there are any mistakes.
- GTM
- LTM
The issue is on your ltm server itself. From the 3rd screenshot its evident that your LTM server is marked offline by the GTM. You need to focus on bring the LTM server UP by the GTM.
Can you check the Iquery mesh for the LTM server.
Please follow this troubleshooting article,
