GTM region based load balancing under Single Wide IP
GTM Load balancing should be done in the following way. If source IP is from US region traffic should hit pool member-1 ,for other Source IP regions traffic should hit remaining Pool member-2,3. All Pool member falls under single wide IP. kindly suggest
Start by reading the section below on topology records. This allows load balancing based on source IP address of the Local DNS server and may fulfil you requirement
