GTM redundancy across different data centre question
Hello,
We have GTM in three different location running in old box with old software v. 10.0. We are going to replace them with the new hardware running latest software. I was wondering if the iQuery between old and new software version is supported? We plan to replace the box one by one if supported instead of replacing all three at the same time.
Thank you.
Should be OK if you use big3d_install - 404 Page not found | BIG-IP Documentation
You can get problems… For example running 11.2.1HF6 and 11.4.1HF2 in the same GTM sync cluster results in the 11.2.1’s NOT updating their VS lists when using auto discovery (I’m not sure that’s documented as a feature either).
H
