We have a set up to resolve wide ip urls abc.makemehappy.com and xyz.makemehappy.com which is forwarding to the downstream LTM BIG-IP. Our DNS is deligated to GTM completely, means*.makemehappy.com should resolve from GTM.
Now i have another URL 123.makemehappy.com which needs to resolve from downstream dns servers. Can i configure GTM in a way that any URLs which is nor present in the wide-ip list should forward to other downstream dns servers?
Please help.
-Freek
Greetings, This looks like the answer to your configuration question. Seems a fairly simple setup fortunately:
Kevin
Hi Kevin,
This solution creates a listener and forwards to the DNS servers.
My requirement is to resolve the wide-ip in the zone first. If the wide IP doesn’t exists, need to forward it to the downstream DNS server. Would this help?
Greetings, In this situation, BIG-IP DNS checks incoming DNS queries and if the query is for a wide IP, resolves the query. Otherwise, BIG-IP DNS forwards the DNS query to one of the servers in a pool of DNS servers, and that server handles the query.
Give it a try and let us know!
Kevin
